I had started a thread on this before but couldn't find it.....anyway, this amp uses a quad switch..actually two of them....NJU211.....I had ordered a DG211D but it isn't compatible....anyway, the one on the power amp board is actually part of the pre-amp ckt...and that is where the problem seems to be....Pin 11 has 15V on it.....it should be zero...I have it installed in a socket...so I should be able to remove the chip, and going by the schematic, use jumper wires to wire up the switching configuration to get the amp to produce sound... I can scope the signal all the way up to pin 2 but nothing on Pin 3 and pin 3 feeds one of the jacks at the rear of the chassis....and I believe pin 7 does the same thing......there are no signals coming out.....the chip does have the proper voltages at pins 4, 12 and 13......and I also noticed that the op-amps, U2 and U3 have DC voltage at pin 7....over 1 volt actually.....pin 1 on these chips checks fine.....so it looks like I have multiple issues?? I will do some more testing and post the schematic later this evening as it is over to the shop.....
Cheers
Cheers
