Last night, I took out the 1000pF ceramic cap and swapped in a .0033uF [edit] orange drop which fit fine. Cathode cap is upgrade to hi-grade semiac? type. Can't recall the exact name again but it still electrolytic. Was this ok?
I might swap in a 1.2 V rechargeable AAA battery yet as I love this sound.
I forgot to write down the plate voltage but it is likely 50V too high
as I'm using an Apex 460 power supply. But the tube seems fine still...a 6ZH1P.
The transformer sure seems big/robust.
Question:
If I were to add a pre-transformer-Send— via drilling a small hole in the mic's-case rear and add a "mini" jack maybe like 1/8"—would this net a purer sound option? So basically a Send right from the tube.
I have an extra wire, I think, along the long Muti-wire cable but I was fearing cross-talk.
Question:
