Hi there
I've breadboarded this pedal and it works fine. I get a lot of the passive electronic stuff that's going on, not sure about the PT2399's but that's for much later. What I can't get my head around is how the switching works. With only the 9v applied voltage to the switching circuit (top right of schem) I can't see what it can do to alter the Q1, J112 gate voltage to make it switch. It DOES switch, and I see generally about half a volt more when the IC/reverb part of the circuit is on. The on-off gate voltages wander from (off; -0.5v, on; 0v) to around (off; -1.5v on; -1v). It wanders around a fair bit, but generally always works once I've fixed all the wires that come loose. It could be that my variance is caused by relatively-complex-circuit-on-a-breadboard, but either way I don't get how, with that reverse biased diode D3, the gate could be changed in voltage via the switching circuit. Or is there some kind of small voltage allowance of a reverse biased diode, before it blocks current, that I haven't heard about yet?
Generally, I get confused when theres a reverse biased diode FACING the working voltage but something later on responds to the earlier voltage change, I've seen it in a few circuits and found a few explanations but none that illuminate me to this particular circuit!
I've read all manner of tutorials going into JFET usage that for far into the detail of the different zones you get at different operational points but nothing that has that diode (d3)...
Thanks for any help
PS - not looking for an in depth lesson, one sentence that I can research further off would be very welcome
Thanks for any help
