Hi,
Today I was tracking a guitar amp and a dry signal coming off a split. I had a ground loop causing hum on the dry signal so I bought a cheap iso transformer; a Rolls HE18 Buzz Off.
It seems to have gotten rid of the hum but there's a signifigant reduction in signal and the frequency response seems to be less than flat... there's a peak that's associated with a portion of the fretboard positions.
I know I've got some issues because I have 1/4" TS unbalanced lines going into and out of a device set up for 1/4" TRS lines. I'm having a hard time finding a unit just for 1/4" unbalanced. At least the Buzz Off has 10kΩ input and output impedance.
I searched tonight and can't find any premade 1/4" TS unbalaced iso or hum eliminators.
I would like to avoid going from unbalanced to balanced ala direct box because I want to use the hi-z input on the API preamp for my dry guitar tone.
I took a quick look at the Jensen site and am thinking about a D.I.Y. project built around one of their trannys.
Does anyone have a low signal loss, flat and wide bandwidth solution for this? Especially something that maintains similar impedance bridging as would occur with a direct connection to the API preamp.
thanks,
mike
thanks,
mike
