I'm working on a Marshall compressor and some of the wires used in this thing won't take solder.
They look like they have some kind of black coating on the strands. When heated with my soldering iron, the black stuff bubbles a little like some kind of oil or something. That must be why many of the wires are in little plugs with crimp pins and soldered on the pins. I'm yanking out some of the pins because they're badly corroded (why I'm working on it).
Any way to make these wires solderable or am I looking at replacing them? Some way to clean them?
Should I dip the ends of them in FeCl to etch them a little?
I tried rubbing alcohol, but even after a 10 minute soak it didn't remove the black stuff from the wire strands.
Cheers
Cheers
