When building a plate current meter, do I put my binding posts in series/in circuit at the cathode, pin 8 for octals using pin 8 as the cathode. My adaptor will be used in conjunction with a tube tester. I will be plugging in the tube on my adaptor and running a home-made lead with an octal plug which will plug into the tester. I'm looking to measure plate current. My DMM will measure plate current at the binding posts.
thank you.
thank you.
