i have a late 70's analog drum machine made by BOSS, it's a small unit about
8"x4"x1.5". i would really love to have it in working order again!
when i picked this up a year or two ago and it had no problems. i built a battery-clip-to-power-jack coupler for it and i believe i may have reversed my polarity. i don't have the coupler anymore, unfortunately. so i can't confirm 100% the cause of failure, but i was using a reliable 6v power supply so i can't imagine what else would've went wrong.
basically, i hooked up my coupler and plugged in the power source. and when i went to test the pedal, it didn't work. i immediately unplugged the power source and retested the unit with batteries. in it's present state, it makes sound when you press the "play" button, but there's no sequence of sounds. it just makes one sound when you press the play button. i already checked to see if there was a protection diode that blew from reverse polarity, i didn't find anything. and obviously, the unit still powers up, so getting juice is not the issue.
i have a Boss write-up for the drum machine but wasn't able to make it of any use. wondering if anyone can tell me where to go from here?
