Help Me
  • Help Me
    I need some help if anyone can! I have a studiocraft f1 power amp, i dont know any technical information! Bought it 2nd hand about 3 years ago, need to know output and ohms! have pictures of it if helps.
    Help me someone!
    Hello,
    power amps can be used with 4 to 8 ohm speakers how ever some amps can go as low as 2 ohms stable depending on there rated out put power!
    if your amp is bridgeable use 8ohm min only in this mode, if it's not bridgeable then a pair of 8ohms speakers rated 300wrms upwards would be ok.
    amptech
      help me
      Hi there,
      Do have have a picture of your amp?
        Any chance some of this information is printed on the rear panel?
        casibom< giriş/a> betturkey
