Current draw on 4, 6 or more power tubes
  • Current draw on 4, 6 or more power tubes
    When reading current draw vai the transformer shunt method, logic tells me that I need to divide the reading by 3 when working with an amp with 6 power tubes.....3 to each side of the OT primary. Am I correct on this one?
    Any help is appreciated. I am looking at a Boogie Buster BAss 200. The amp is running well and sounding good, but I am the inquisitive type and would like to have a grip on the performance parameters....draw, plate voltages, plate dissipation and such.
    Also, for future reference, what about with an amp such as the Boogie Bass 400 with 12 6L6's....6 on a side??? Divide by 6?
    George at Boogie confirmed my feeling that one should divide the reading by 3 in order to derive current draw per tube in this particular set-up.
    Thanks for looking.
      dividing by three will *not* tell the whole story. For instance, if tube #1 is drawing 52 ma, tube #2 54 ma, tube #3 75 ma, you will figure bias is 60ma per tube, when it is not! With 6 tubes in parallel push pull, or even four, you may as well put in a 1-ohm resistor in the cathode (each millivolt=milliamp across it) for individual measurement, and perhaps adjustable bias per tube. All tubes are different, and so all tubes draw different bias current for a given grid voltage or cathode resistor. You could have one dodgy tube that causes you to set the bias entirely wrong instead of replacing the tube.
        6267, points well made and taken, and thanks for the insight.
