The 400 B/G and 400 BH were very similar and more or less interchangeable. They could have mounted either one. The rear panel was printed for BH because most of them used that one, but if there was a production shortage, the other could be used. They have the same ratings. Believe what it says on the board.
SOme of the part numbers differ, and there are subtle differences. I posted the 400BG on www.ampix.org in the Enzo gallery.
When a part reads open like that, reverse tour ohm meter leads and measure again. If this time it reads "negative resistance," then there is voltage present - usually just charge in a cap. It is sufficient to lift just one end of a part to test it.
You don't have to remove parts to test them. A shorted component is not going to read as not shorted from being in the circuit. If it reads shorted, then pull it and retest. After all, if it is shorted it has to come out anyway. There are often parallel circuit paths that result in lower readings than the part itself. A look at the schematic usually reveals those cases.
Start at the start. Use the right schematic for your board - the 400BG apparently - and verify all the DC readings on the schematic are reasonably similar.
