I'm restoring this console for a buddy and I am at a crossroads on the setup of this unit. It has two push pull 6V6 amps, one for the 4 speakers in the console and the other amp for an external "stereo" speaker which they do not have. I am tempted to split the speakers into spares and run both amps but I will end up with two 16 ohms pairs instead of the needed 8 ohms. I kicked around throwing an 8 ohm sand resistor on each to even things out but realize I will loose a lot of power through heat that way but they will have a stereo phonograph and likely a little more volume overall. How would y'all proceed?
Silvertone 69a Console Speakers
Yes I have that plus the preamp and radio if interested. The phono is stereo but I don't think the the radio is as it has a RCA input for multiplex? I guess this was sold separately. They do want one of these bluetooth modules added so I'd like to give them a stereo out if possible.Last edited by tdlunsfo; 08-11-2020, 07:44 PM.
