CR2032 15mm pin spacing
  • CR2032 15mm pin spacing
    Hello,
    I need to replace a battery for an old Yamaha SPX 90, and I have a lot of trouble to found a battery CR2032 with 15mm pin spacing for solder to PCB.
    Anybody can tell me where I can buy here in Europe?
    Thanks.
    Have you tried Conrad ?
    https://www.conrad.be/p/cr2032-knoop...-stuks-1009402
      You can get them from Amazon as well. (And probably from around a dozen European distributors).
        Or if you can find a coin cell holder to install, then plain old batteries from the store will snap in.
          Yes, this was the main idea. But I can't find any battery holder with 15mm pin spacing.
            SO fake it. SOlder one end of the clip into the board. TAck a short wire to the other terminal and solder that to the appropriate board place. Put insulating material under the clip.
              I think this was how we did it even when these units were not terribly old. The proper batteries were hard to find and expensive even then.
                I used enough of them I stocked batteries with pins. Seems to me I bought them from Digikey, and didn't find them expensive. But later I decided sockets made even more sense.
                https://www.digikey.com/product-deta...659-ND/2404064
                  I found this one:
                  https://www.tme.eu/es/details/bat-cr.../6032-701-020/
