I have a young tech that I occassionally give aid to. He's pretty sharp & it's my opportunity as an older more experienced tech to impart my knowledge before I'M too old . So he calls me with a typical 6L6 Push-Pull Fender amp that he's replaced the typical screen and cathode resistors. He's only getting 5watts out of it. He's already (out of desparation) replaced the output xformer.
He's checked all the voltages around the power tubes and all seems reasonably normal but the highest he can get the idle current is about 5ma.
So I double check the plate, screen, control grid, & cathode voltages and aside from the really low idle current, I find nothing obvious.
I decide to see if we can raise the idle current to at least get the power tubes closer to their normal idling current buy bridging the 27K resistor to ground from one side of the bias pot with I think a 1K resistor.
We were able to raise the idle current to something like 15ma and the power tubes began to get hot BUT the voltage on the grids in order to even draw 15ma as nearly 0V! Normally of course, that would have had the tubes red-plating.
Upon driving the amp with a 1K signal the output still was very low and had crazy cross-over distortion. The 1KHz drive to the grids was more than adequate but also had the same cross-over distortion. I attributed that to possibly being a result of the neg feedback.
Upon knowing the issue had to be at the power tubes I rechecked the voltages on the 6L6's.
Low and behold the screen voltage was way down at like 40V. What the hell I proclaimed out loud.
I found the screen resistors on the board & immediately found the issue,
He had installed 470K resistors instead of 470ohm resistors.
The reason I dragged out this repair story is just to share the experience as since I've only seen completely burned up screen resistors that I would have replaced immediately given just their charred appearence, I've never experienced how an output stage would respond if the screen resistors were just too high a value to be able to handle the current the screens draw at idle OR the reaction the wrong values created when put under load.
Anyway, there ya have it. A great new experience for me and a great lesson for a newbee...thanx for listening...glen
