Hi, Iv been trying to fix this for about 2 weeks now, the PMP3000 powers up i can get sound from headphones all inputs work, it has 2 problems the LED readout for FX is missing segments (not to stressed about that) and no Amp output
the amp in my pmp3000 is a HCA2400 and i have a question, the amp it self was not burned up and my voltages seem ok , but no output, the other day i flipped it on to do some more testing and it played for like 3 mins when i had it on the test bench i could not find any voltage differences!! maybe a bad opamp ?? also on connector 6P pin 6 i have -14V and its labeled as OFF should that be a positive voltage ? the other pins on that connector 6P are
(p1) +11.8V
(p2) Agnd
(p3) -12V
(p4) Pos+ -14V
(p5) Pos- -20V
(p6) OFF -14V
the +12V line is a little low i have changed out all regulators in the power supply already but still 11.8V dont know if that's enough to make the amp fail to power on what do you think ?
note mixer board settings are correct, i can trace audio directly to the amp its making it there with out any problems.
(p1) +11.8V
(p2) Agnd
(p3) -12V
(p4) Pos+ -14V
(p5) Pos- -20V
(p6) OFF -14V
