Hi All!
So I got a used atmel programmer/dev board a few years ago, no power supply. I got some parts from ebay and made a 5v ps. The cheap ps kit came with LM340 5v 1a and LM7812 12v 1.5a regulators, and the smallest heat sinks I ever saw. Idle it was OK but as soon as I tried to do any activity with the programmer board, the heat sink would get piping hot too hot to touch. I dug around, found bigger heat sinks that fit the ps board (can't remember think it was mouser). They are over 3x the height, and probably 10x the mass. The sinks don't get too hot to touch but I think still way too hot, although I don't have any way to measure the temp.
I keep an eye out for throw away electronics, and lucked into an old Samsung stereo system. A cheapie, not worth fixing. But the audio amp box has two HUGE heat sinks. Big fins, The back of the heat sinks are probably 3" tall x 8" wide, with big heavy fins on the other side.
I have not the slightest idea what size to cut these down to for this 2 x LM340 (double) power supply. I have a couple of old computer power supply cases that Im going to mount the boards in, it has a fan iec power connector and switch. (benfits of rooting through the trash).
If I cut the heat sink the width of a standard ATX power supply, would that do it for both the 5v and 12v regulators?
Thanks
Mike
Thanks
Mike
