Hey Folks,
https://www.magnatoneamps.com/schema...-schematic.jpg
https://www.magnatoneamps.com/schema...components.jpg
After a lot of elbow grease and tracing and repairs, I've finally got a Magnatone 240SV to output sound on both power amps. The previous owner had snapped 2 PC boards in half trying to take it out of the chassis, re-soldered the entire thing back together and done a lot of other monkey business, but now we are able to probe good audio all the way through until we get to the two speaker output leads with no load connected.
The signal passing through the leads on both power amps are the same volume and roughly the same quality, but when we hook up the "right" (when viewed on the schematic) power amp to a load, the signal instantly sounds like crossover distortion. Unplug the speaker, probe the terminal, and everything sounds good, so it is only acting up under load, meaning that we're looking at any components that interact with said load...
I do have bias voltage at the trimpot symmetrical to the other side at around .7. Trimpot measures at 50k total, 35K actual.
I do have 20v coming to r302 on both sides.
I have replaced all the electrolytics and measured each resistor on the "problem side".
MY guess is that when the amp sees the load, the outputs activate and one of the two is malfunctioning , or possibly the pre-drivers are not supplying enough voltage for the outputs to properly amplify? Can I switch the OT transistors to see if the problem follows the transistors?
I've learned a lot through these posts about SS outputs and am looking forward to improving my skillset, I have a lot of knowledge gaps in this area.
Thanks!
Thanks!
