Help to find Tactile Switch
  • Help to find Tactile Switch
    Hello,
    I need to replace a tactile switch from stomp box pedal. It's a momentary SPDT switch. 6x6mm. 2 pins.
    Thanks!
    There are hundreds to choose from. Once you have established the correct pinout you will need to check the travel, the heights and the feel.
    I narrowed it to 300 or so from 5000+ but the rest is up to you
    https://www.digikey.com/en/products/...AdwF2JAALZnEgA
      Looks like E-Switch TL58/59 series like this: https://www.digikey.ca/en/products/d...9AF160Q/390534. There are others with different button lengths
        One thing to help your search, with only two pins, it is not going to be a SPDT, It pretty much has to be SPST. Digikey and MOuser have huge selections, though 2-pin are way less common than the four pin.
