Still seems high to you compared to what? Was the B+ less than 358VDC with the old noisy transformer?
Transformer quandry
Doesn't make a lot of sense if the original PT had higher unloaded voltage. But the unloaded voltages had to both be measured either with or without those CT resistors.
Could that account for the difference?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Randall View PostThat is why I am confused, both measurements are with CT resistors and tubes in. Something isn't right.
- Likes 1
But the thing is, it worked the way it was built, it just made mechanical noise. So the customer opted to replace the PT with one close to what I was measuring in the original. But now the new one seems to high in voltage. I am stumped here.It's weird, because it WAS working fine.....
