Should I run a 2-12 Vintage 30 cab at 4ohms or 8ohms. States use a 2-12 Vintage 30 cab at a 4ohm load into the Amp along with the 3-10 in the Amp. Just wondering about a ext cab running at 4ohms into the Amp will it hurt it or should I run the ext cab at 8ohms not 4ohms.
Fender VibroKing
Your three 8 ohm Jensens make a 2.67 ohm load already.
I am not sure how a 2x12 cab can have a 4 or 8 ohm switch. Only way I can think is if it is a stereo cab, so 4 ohms mono, or 8 ohms for each side in stereo. If that is the case, you could use just one side of the stereo for 8 ohms in the cab. If you run it in stereo and connect two speaker cords, it becomes 4 ohms anyway. Please clarify.
An 8 ohm external added to the 2.67 ohm internal makes 2 ohms. And a 4 ohm external drops it to 1.6 ohms.
Would that HURT it? Likely not, but I have my doubts as to it working so well.
Just my opinion.Education is what you're left with after you have forgotten what you have learned.
The Fender VK extension cabinet was 4 ohms.
https://www.guitarcenter.com/Fender/...ker-Cabinet.gc
