Grids 40 p to p. Output at speaker. 2-3 p to p
Ibanez TSA15H Low volume
Originally posted by mikeskory View PostShape looks ok. Past 3/4s volume it starts distorting at the bottom. It will start oscillating at near full. Want a pic?Last edited by Helmholtz; 05-22-2021, 01:10 PM.- Own Opinions Only -
- Likes 1
Originally posted by mikeskory View PostHere you go. Top 3 input to grid. Bottom 3 outpt to speaker
Speaker signal is asymmetrically distorted but not clipped. Def. too small.
I would test the OT using the neon flash test.
Did you check idle currents?- Own Opinions Only -
- Likes 1
23 ma when I calculated it it should be 27 ma FYI https://www.premierguitar.com/the-su...sformer-tester
I prefer the neon test below:Attached Files- Own Opinions Only -
- Likes 1
Hey Enzo! Yes tried different speakers, dummy and all the jacks. I also pulled out the small output board to examine, resolder and clean the switching jacks. Now I'll look for a trans. It's a store-stock item so I don't think they"ll want to spend a lot on it.
