Hey everyone,
Got an Orange Matamp clone (one off, no schematic) on the bench, symptoms are low Clean Channel volume. Distortion channel sounds nice and loud. Guessing the amp is a MKII clone, but the schematic may not help considering the issue....
This is a custom one-off channel switching amplifier, I was able to trace the signal all the way through the preamp past the master volume but the signal is reduced dramatically after an Optocoupler. There are two optocouplers tied to a g5v relay, each one feeding the respective channe'ls master volume into the PI.
After bypassing the optocoupler completely, the signal returns, so we know that either the optocoupler or something connected to it (relay...) is bad. My question istwofold;
1. Is there an easy / recommended way to divide and conquer from here? The issue seems obvious (or at least isolated to this area) but I have never sourced optocouplers that aren't used for tremelos.
2. Without a schematic, is there a way to measure and source an equivalent optocoupler?
Thanks in advance for all you lovely folks.
