Marshall Stanmore bluetooth amp.
  • Marshall Stanmore bluetooth amp.
    I'm not sure if this is something that is topical for this website but I'd appreciate any help. I'm working on this Marshall Stanmore bluetooth amp. It's dead. I have 160V raw B+ but that's it. I can't find a schematic. There is black hard glue on components covering part numbers. Has anyone had success repairing one of these? Thanks for any input.
    Can you elaborate on 'dead'?
    No power led?
    No sound output?
    No Bluetooth connection?
    160Vdc on a small unit like this seems a bit excessive.
    Or is that on the SMPS capacitor?
    This video seems to show a short at the power in jack, possibly caused by the 'black goop'.
    https://www.bing.com/videos/search?q...7&&FORM=VDRVRV
    (Cannot understand the language, Vietnamese maybe?)
      Hello Jazz P Bass: Dead...no lights anywhere, no sound at all. It does have a SMPS which is where the 160V is on the capacitor, no secondary voltages.
        I did repair a Marshall bluetooth speaker, and the odd trick was, it would not power up (EVEN WHEN PLUUGED IN) until I replaced the dead lithium battery pack, then it worked fine. Good luck!
        EDIT: I looked at my records--it was the Marshall Tufton.
        http://amps.monkeymatic.com
          Thanks Xtian, but this one doesn't have a battery.
            Often, the cause of a SMPS not running is shorted diodes on the secondary, so I'd start by checking those. If you have a scope, see if it tries to fire up and then shuts down repeatedly. If it does, it's likely protecting itself and there is a short on the secondary. If it doesn't fire at all, it's more likely a primary side issue. That's about all the help I can offer without a schematic. Also remember that an SMPS primary has it's own ground, so don't connect a scope to primary ground unless you like fireworks.
              Thanks for the suggestions. Yes there is a lot of black goop on the board so it's hard to check components. I think I'll scrape as much as I can then try check for secondary shorts. I'm wondering if this black goop is conductive.
