Backup battery Installation
  • Backup battery Installation
    Hey, guys!
    I want to install a backup battery in a vehicle so that I may use one battery to run the radios and other electronics all the time and not drain the primary battery.
    I've looked through the forums but haven't found any information on how to achieve this.
    I'd appreciate it if someone could explain how I can hook this up.
    You need a split charge kit, explained here;
    https://www.truckelectrics.com/blogs...arge-kit-guide
      I think your friendy Car Electrician who in any case will make the installation is competent enough to do it.
