What i'm trying to determine is this....if you have two 9v batteries and one is 500 Mah and the other is 250, will the 250 drain down to a given voltage twice as fast as the 500?
Here's another question to irritate you all with.
If you run 2 or 3 low current effects like tube screamers and such off one battery, what other negative considerations might there be besides faster drain? I'm running 2 off one battery now, a RAT and a tube screamer and it sounds fine with no ill effects what so ever. I'm thinking about running the 3rd off the same battery too, a TC electronics spark boost.
