Sorry about starting a new thread, but because i wrote the last post in the other one where i suggested i was done i figured no one would know i posted a new question. So to those like mick and enzo, G1, Juan etc who were helping me, i have a question when implementing enzo's suggestion to put a diode in series with the regulator's ground leg to change the 8v out to 8.5. Theres a 22uf cap that goes from the regulator's ground leg to the + out and what i am wondering is should the cap go to the regulator's negative leg or to the cathode of the diode same as the battery negative ?
another regulator question
Quiescent current of the LM2940T you're using is up to 60mA max, twice the 30mA draw of your pedals. Even the typical quiescent current (estimated from the graphs in figure 4 at an output current of 30mA) is going to be in the range of 15mA, a full 3rd of your current budget just to power the regulator. This was not a very good choice for battery operation.
Here's the datasheetLast edited by Greg Robinson; 12-04-2021, 04:45 PM.
Originally posted by Greg Robinson View PostQuiescent current of the LM2940T your using is up to 60mA max, twice the 30mA draw of your pedals. Even the typical quiescent current (estimated from the graphs in figure 4 at an output current of 30mA) is going to be in the range of 15mA, a full 3rd of your current budget just to power the regulator. This was not a very good choice for battery operation.
Measure input and output current of the regulator with full battery and load connected. The difference is the current through the diode.
Or directly measure the diode current by inserting your Ammeter between the middle pin and the diode.
What regulator are you using?- Own Opinions Only -
Originally posted by Helmholtz View PostMeasure input and output current of the regulator with full battery and load connected. The difference is the current through the diode.
Originally posted by daz View Post
LM2940 8v. Measured 11.6 ma with the 2 pedals i am powering on. one is a 4ma pedal, the other is a tube screamer that i think is around 7 maybe. Should i have measured it with pedals disconnected? The battery i just put in is at 10.4v and the regulator output is 8.6v with the diode
(As always, unloaded battery voltage doesn't tell much about charge condition.)- Own Opinions Only -
Is this regulator input or output current? We need both.
edit: between in and out reg legs i get 8 mA with pedals connected and 1.3mA without them connected. Don't know if thats how u wanted me to measure but there ya go whatever that matters.
I measured current by putting the meter set to mA in series with the diode and the rest was battery and output voltage.
Please also measure the battery current (= regulator input current) with load.
Again, always measure loaded battery voltage. Unloaded voltage may fool you.Last edited by Helmholtz; 12-04-2021, 05:13 PM.- Own Opinions Only -
