Modifying Weber Mass 100
  • Modifying Weber Mass 100
    Merry Christmas to you and yourn!
    I've been putting off doing something about this for far too long. It's New Year's resolution time, so here goes.
    I have this Mass 100 attenuator. It has a treble boost switch, a two-position, not the three-position of the schematic. I have to use it at a very low level which makes the bright setting way too bright (but the off position is unusable - too dark/dull). I wonder if I can replace the switch with a pot.
    What say you guys?
    webermass100-gif.186803 (1200×783) (musiker-board.de)
    No, you can't replace the treble boost switch with a pot. You're switching caps in or out of the circuit. But you can certainly tinker with the value of C1/C2 (or whatever is actually present in your MASS).
    http://amps.monkeymatic.com
      What about adding a resistor in series with it?
        I would check how the treble boost circuit is wired up.
        If you only have a 2 position switch what capacitors are in it?
        The 3 position switch may be a later model to cure exactly what you are experiencing.
        You might want to consider modding yours up to a 3 position and adding another 10uf cap in series.
          OR add another cap in series???
          I haven't been inside the thing for years. It has weird screws. I think I have the right tools to get into it now. It'll be a couple days before I can get to it.
            Or just add the series cap to the existing boost setting to tame it.
              The Weber Mass Lite uses a 50R/100W pot for Mids-Highs adjustment:
              https://www.freestompboxes.org/membe...erMASSLite.gif
                Not sure what you're suggesting. That's the Ohmite thing, I think, that you're talking about. Here's some pics of the innards.
                inside weber mass at DuckDuckGo
                  Yes, Ohmite is a manufacturer of power pots.
                  The Weber Mass Lite uses 2 of them, see schematic.
                    I can't put two of them in there though, wouldn't fit. There kinda expensive too.
                    I can't understand why a resistor (flameproof?) wouldn't work in series with the cap.
                      Sure, you could experiment with increasing the value of R7, but it seems you need to use 50W rated resistors.
                        Now we're gettin' somewhere. I'm just looking at the schematic and the innards pic and the mouser catalog - looks like it's not your standard resistor. Something unfamiliar. Have to look into it
                        What about putting a regular resistor in parallel with the existing resistor? Going bigger would mean less bright, I would think?
                          You can't use regular low power resistors here because it's speaker power level.
                          Higher resistance lowers treble boost.
                          You can wire resistors in series to increase resistance.
                            Duh, I was thinking caps not resistor. My mistake.
                            So then, no easy way out. Hmm.
                              Well, I'll be. . . .
                              I opened it up this morning. This version is pretty different from the schematic I posted. I haven't as yet found one for this older model. It has a 2mF treble boost cap.
