Hello folks,
Just entering an issue I had with one of these limited edition Vox AC30HW60's that are British made from a few years ago that were probably around $4K when new.
The issue the customer stated was that with both volumes down (or up) if he increases the bass control, there is a hum that he felt shouldn't be there. It also changed with the treble setting. Ya gotta know anyone who pays that much for an amp is going to be a bit picky. I decided to pursue it rather than just tell him that's how it is.
If I pulled V2 the hum was gone.
Turns out that the shielded cable shield that leads to the brilliance vol pot is grounded on the turret board (& Ultimately to the star ground thru the turret board connection) and is also chassis grounded at the Brilliance channel vol pot case which of course goes thru the pot to the chassis thereby creating a ground loop.
You can unsolder the 2 shielded cables at the brilliance pot case & run a wire to the shielded cable ground at the Bass control which is connected thru another shielded cable to the turret board star ground.
It's a tube amp & of course still has some errant noise, but this countermeasure resolved the hum w/bass control turned up.
FYI for anyone who may encounter this issue.
Thanx, glen
Thanx, glen
