desoldering thru holes & double sided pcb'x
Folks,
The only way to do this with guaranteed results always is with a product called ChipQuik. http://www.chipquick.com/
It is fairly expensive but short of spending the $600 for a vacuum desolderer, this stuff is the bomb. I've used it for years on Flatpacks up to 114 pins ( a must for keyboards) as well as any type of thru hole components. It will save your tearing up the clad when you're not certain you've got all the solder out.
It is a high lead per tin composition & melts at a relatively low temp. It stays molten while you add it to all the pins of a flatpack or thu hole component. Once you have it all applied, you simply lift the entire component off the board or out of the hole.
It is truly amazing stuff & I can see they now have a ROHS compliant version.
a small amount is about $20 & for a tube of the stuff is over $100, but will last for ever if you're stingy with it. glen Mars Amp Repair
Folks,
