Hi all,
I´m trying to add an adjustable line out to the MIC2 channel of a Bogen MXM mixer/pre.
Pls find schematic attached for the Bogen unit.
So far I´ve disconnetcted the Vol 2 pot so the signal is not unnecessarily attenuated and added a simple
AC coupled CF (1/2 ECC83, 280V on anode, 100k cathode to ground).
The CF grid is connected directly to pin 6 (anode; at ~100V) of the EF86 on MIC2 channel.
Now when I scope the CF´s output on pin 3 I get a nice clean signal which slightly compresses with larger signals but never clips
So far so good.
As soon as I add a load (25k pot to ground, in order to make the line out level adjustable) to the CF´s output via a coupling cap
(e.g. 100nF) the signal is at once clipped hard on the bottom part of the curves at all except very low drive livels, see pic attached.
What´s going on?
So far so good.
What´s going on?
