Anyone making custom transformers anymore?
  • Anyone making custom transformers anymore?
    I’ve contacted Merren and Heyboer with no response. Any suggestions?
    By phone or email?
    nosaj
      Edcor has like a thousand designs, with a bit of lead time they're quite capable and not terribly expensive.
        Originally posted by nosaj View Post
        By phone or email?
        nosaj
        Merren by both. Heyboer by email.
        I’ve looked through Edcors catalog. Nothing I can reasonably use.
        I found something from the UK. But the eBay listing is $115 shipping plus the $90+ for the transformer.
        i contacted the manufacturer directly, so Il see what they say.
        i need a 6k6 p-p to 8 ohm 10W or under
          6k6 push pull is something like 12kohm? Some guys on an antique radio forum suggested this one. http://www.hammondmfg.com/125a.htm
          Choose your impedances, choose your power.
          I found Heyboer very helpful when I've called them on the phone.
            How come?
            You nominally need 12kPP 10W, these are 10k-15k (pick one) , REAL close both,10W
            https://edcorusa.com/collections/tub...ut-transformer
            Ready made or a standard product if custom wound.
            Good price.
            And way better than any "universal" one.
              How come?
              Good price.
              Huh?? Where did you guys come up with 12k? I want a a 6k6 (plate to plate) primary impedance, because that's what the design calls for. I'm using a pair of 5902 Beam Pentodes
              I mentioned 10W and under because a 10W OT is as big as I would reasonably use for this project, which is about 3W max as it stands. I would much rather use one that's around 4-5W.
              Edcor's smallest OT with the load I want is 25W I think. Way overkill.
              Fahey, what would it take for you to put your transformer winding shoes back on and build me a nice quality OT for this project?
              *for reference, see: https://music-electronics-forum.com/...-would-you-use
                6k6 impedance or 6K6 tube?
                Edit: Missed post above.
                  Ohhh. I see where we wrong here. I forgot there was a 6K6 tube and didn’t specifically mention primary impedance when i said 6k6 p-p to 8 ohm
                    But, it was a lowercase “k” on purpose.
                    Haha! I was like “ …the balls on these 2 jokers. just doubled the impedance I wanted and decided that’s what we’re going with now”
                      Oddly enough, the post I deleted above was assuming you wanted 6.6k ohm primary, but seemed like an easier answer. Why not just use a Blues Jr. style OT? Is "10W or under" something magical?
                      https://www.hammfg.com/part/1750F under $50
                        Yup
                          Well, in that case I think mercury mag has the exclusive on the magic stuff.
