Behringer EUROPOWER PMP2000D with dead output channels
  • Behringer EUROPOWER PMP2000D with dead output channels
    Hi,
    I am new to the forum and hoping somebody can help me.
    I received a Behringer EuroPower PMP2000D and it has dead main output channels (L and R), but with the INPUT level indicators showing some life when i plugged a microphone or any input device in the INPUT channels...
    I tried dismantling it and reseated the flex cables and cleaned them with contact cleaner and plug it back.. At least the Right Output Channel (speakon-type) begins to work. However the Left Output Channel is still dead. I tried cleaning both speakon-type output connectors and even swapped them just to confirm it isnt the speakon connector is the problem.
    Still with the same condition, the left channel is dead totally dead.
    I will try to probe back from the left channel output going back to the board and see what i can find.
    Hope you can share me your ideas too. thank you
    Try cleaning the Main/Monitor/Bridge switch on the front panel. If that doesn't work, it's best to start scoping through the circuit and see where audio is lost on the nonworking channel.
      thanks The Dude i will do that on my RD. Appreciate the tips
        I did clean the toggle switch for Main/Mon/Bridge with crc contact cleaner and used a small hose to probe in and wiggle it back and forth without success.
        Anyway, i will see what i can do.
