Kw153 cutting out at low volume
  • Kw153 cutting out at low volume
    Hello I have a qsc kw153 that is cutting out at relatively low volume. It is not a mechanical issue or bad pot/connection. The amp will start cutting out after a few minutes of playing at a low volume and then after 5-10 minutes of turning it off start working fine and repeat the proocess. Is this a known issue?
    I'm currently away from the AP maker and will get more relevant information right when I return...just curious if this is a known issue and I had trouble using the search to find any relevant threads. Thank you!
