Hello,
I've some questions about a good GND scheme. I read a few articles and I didn't see any consent about it. So, I draw two schemes. Wich one is better?
Scheme 1.
each XLR cable has its shielded cable. And chassis to pin 1. IEC earth anywhere bolt on the chassis, near the IEC connector.
Scheme 2.
Only first input have the shield cable to the pin 1. Pin 1 distribute shield to the others connectors, rest of the XLR cable only have shield at one end. Chassi and IEC earth soldered to pin 1 of input connector.
I read that the earth connection of the IEC socket need to be near to input power, bolt on chassis. Some others says that the earth connection need to be soldered at pin 1 of the XLR input connector.
Any suggests?
Scheme 1.
Scheme 2.
Any suggests?
