Originally posted by dai h.
View Post
The "fat cap" mod, that is the 250uF to 470uF cap bridged across the V2A cathode resistor is confirmed by Dave but didn't come into use until much later and the amp may not even have ever been recorded in this incarnation. Eddie said "All these techs that have worked on it really f#@%ed it up". The "fat cap was added at some point to fatten the tone to where Eddie believed it sounded more correct. I might speculate that the amp may have had .022uf coupling caps for both channels once upon a time and some tech may have "corrected" that. Later, the fat cap mod restored a little of that lost bottom end. But no later tech ever thought to change the bright channel coupling cap from what appeared to be stock. But this is just speculation. I don't put much importance on the fat cap because it was a very late addition to the amp when Eddie was trying to get it to sound right again.
Your info on the pickup may well be correct for VH1 and I don't know what all else later. I've read similar as well.
The PI coupling caps are reported to be .022uf by Dave. I can buy this because some Marshalls "swirl" more than others and I've sometimes suspected that this may be due to duty cycle shift caused by grid loading on amps that may have been fitted with .1uF caps randomly (at times when .022uf caps were in short supply). I don't recall EVH's tone being real swirly.
As to other stuff... Extra filter stage, etc. I never saw anything about that. Very early on the amp DID have a pot on the back panel. It was removed later. The popular speculation is that this was a Jose installed master volume that was put in experimentally because when the band was not yet famous Eddie needed to manage volume for different sized gigs. When asked about the mystery pot in an interview Eddie did not reveal what it was and only said "I always just keep that all the way up". It was removed and the hole was plugged with a slot drive screw in the very early days. This clearly demonstrated that the amp WAS modded after all. Though just how much so and whether it was modded in any way that matters will always remain up for debate.
Also, Eddie was notorious for just saying things to perpetuate intrigue. He got this instruction from David Lee early on after a lack luster radio interview and ran with it. So pretty much anything Eddie ever said about the amp should be taken with a grain of salt. I didn't see anything about unmatched tubes or his amp red plating in my own (shallow) research. I have to wonder about that anyway because it seems to me that if voltages were adjusted one way or the other with a Variac then the bias voltage would have been analogous to that adjustment. Less than perfect but probably not that far off to cause red plating.?. Unless the amp was already incorrectly biased.?.
I saw those squashed green caps in one amp and wondered what the hell they were. I didn't know they were OEM.
