Do let me know if there’s a better place to post this in.
I’ve recently acquired an old mixing desk cheap because it was without its power supply - a common scenario which can be a good way to get a bargain! I thought I had a power supply hence my willingness to buy the desk. Turns out I have a Yamaha PA-10 PS which is an 18.5v AC X2 supply rated at 0.62 amps delivered through a GX16 aviation 3 pin plug. Unloaded it reads approx 21V between pin 1 and 2 (Gnd), the same between 3 and 2, and 43V between pins 1 and 3.
The mixing desk I have purchased was supplied with a similar supply but 17.5v AC X2 rated at 0.94 amps, model PA-20.
I’m happy to buy a replacement - they’re readily available if a little pricey - but it left me with a couple of questions, one practical and one theoretical, that I wondered if the forum members might have views on.
1. Although I’m happy to buy a replacement PSU - the desk cost me not very much after all - I’d like to see if it’s working beforehand. How sensible do you think it would be to temporarily and briefly hook up the one I have - 1V over and underrated by 0.3ish amps - to see if it powers up?
2. How are three pin supplies like this constructed? Is it a 2 phase supply with two ACs out of phase? Is it
just like a 2 pin AC supply but with an inverter included? Are there 2 coils/transformers or any modern switching equivalent needed in a unit like this a - little like a makeshift Eurorack PS I cobbled together to supply +12v and -12v (dc in that case)?
I’d be interested in your thoughts if you’d like to share them. Thank you!
