Mesa Boogie Strategy 400 -- why mismatched screen resistors?
  • Mesa Boogie Strategy 400 -- why mismatched screen resistors?
    Each channel has six 6L6GC tubes. Four of them have 470R/2W screen resistors; two have 2K7. Why?
    Schematic attached.
    http://amps.monkeymatic.com
    I'm asking, because one of the 2K7 screen resistors is burned, and I need to replace.
      Huh, found a likely explanation: https://www.thegearpage.net/board/in...class.2359616/
      You can replace the last row of 6L6 power tubes with EL-34 power tubes for more grind.
      This is supported by the manual https://mesa-boogie.imgix.net/media/...0%20Stereo.pdf
      All twelve sockets should be fitted with STR 6L6's when the Strategy is being used in any application other than live guitar. We have specially adapted 4 of the sockets-- those along the rear edge-- to accept either 6L6's or STR 416 type 6CA7/EL34. This tube is characterized by more prominent harmonic output when driven hard which produces a brighter, more grinding high-end, usually preferred for guitar. No internal changes are required; the two type of tubes are immediately interchangeable.
        Channel A failure is stumping me. Something is drawing excessive current. I'm getting very low voltage on the plates of V1. (I tried new tubes already). With V1 and V2 pulled out, I see a 100v drop across the 22K/2w resistor, which is weird, because there's nothing to pull current. Comparing with Channel B (also with V1/V2 removed) there is only 1.5v drop across that resistor. I tried lifting one leg of the 30u/500v cap thinking it might be shorted--no change. Voltage drop across the 1N5368 Zener is the same on both channels, about 47v. The only path I see for current to leak from B+ to ground is via the 0.1uF post-PI coupling caps--but there is zero voltage on pins 2 & 7 of V2.
        Any ideas?
          It's been quite a while since I worked on one of these. Do both amps share the same power supply?
            The schematic doesn't look cpmplete.
            Does each channel have its own 22k/2W dropper (and zener)?
            If so, does it measure good?
              Yeah, I cannot find a better schematic. It has a single PT, single rectifier, and B+ is tied together for both channels. After that, it has individual filtering and the rest of the downstream circuit. Each channel has it's own 22k/2w and Zener, and both Zeners are dropping 47v.
                Did you measure the 22k dropper of the bad channel?
                Is there maybe another filter cap after the zener?
                What happens if you switch PI supplies between channels?
                  Found the issue! Fully shorted 0.1uF coupling cap between V1 and V2. Replaced, issue solved! Amp is running and sounding OK. Thanks, friends.
                  And here's a happy little thermal photo for your amusement.
