Hello all,
Does anyone recall if the bias setting on the SVT3pro is extremely touchy? It's been a while since I've worked on one of these & my notes don't indicate anything about this.
ton iThis particular amp, just moving the pot a minuscule amount from proper bias of about 20mv, results in the bias jumping to over 100mv and if you continued it would allow a setting of over 200mv (across one of the source resistors).
I'm going to check Q2 next, but wondered if this effect is normal for this model.
BTW, the pot tests very smooth with no jumps on the bar meter of my Fluke 87V, so it's not worn or noisy.
Thanx, glen
Thanx, glen
