Hi Everyone.
More than, or about, a month ago, many of you helped me figure out a situation with a new power conditioner that I purchased, a Black Lion Audio PG-2 (here is the original thread). Now I am back, same product, very different scenario...
My power conditioner has been reporting over 240 V coming from the wall, depending on the time of day. It's within spec as far as I understand (should be 230 VAC), but the last few days it has been over 247 a few times. When the voltage reaches 245 VAC, the power conditioner shuts off to protect the connected gear.
The larger problem is that "during office hours", when most people in my neighborhood are off to work, I find I am not able to run my system until later in the day when people get home and start putting a higher load on the grid.
Coupled with the fact that many in the area (myself included) have solar panels which is placing even less of a load on the grid.
Of course, this is my interpretation. I am not an electrician, so please feel free to correct me.
Then there is the fact that I have some tube amps that need that voltage to be under control as well... I have a 1969 Laney Supergroup that is already set to 250 V on the back of the amp (power tranny tap) and was barely staying in proper(ish) EL34 heater range last time I measured it (~3.5 V per pin on EL34) - but then my power was consistently 230 VAC +/- 2 or 3 volts.
Are there any suggestions on what I should do, if anything?
Thanks, as always, for your expertise and time!!
I am adding a few pics to illustrate the point, which I imagine you already get.... just being thorough! :-)
