Hello folks,
Has anyone had the repeated experience with the JJ brand 5AR4 rect tubes?
I have had numerous issues where these tubes will arc/short on with the initial inrush current even where the amp is designed to use the 5AR4.
I had an amp that drew enough inrush that a few of the JJ 5AR4's would initially arc internally, and then settle down & work until the next inrush.
So, I won't use them anymore. I'm not sure who is the ultimate mfg of these.
I have found the Sovtek or Tungsol made rects do not have this issue. I compare the internals of the Sovtek & the Tungsol reissue rects, and they seem very similar, so I'm guessing the Tungsol is Sovtek made.
So, I use the Sovteks, as they're a tad cheaper.
What you think?
Thanx, Glen
What you think?
Thanx, Glen
