Understanding transistor requirements
  • Understanding transistor requirements
    Is it true that one leg of any transistor will need a DC supply voltage in order to amplify (or even pass) a incoming signal on another leg?
    A BJT will act like a diode if its junctions are forward biased. This means the transistor can pass a half-wave rectified signal without any DC being applied - so long as it is greater than the forward voltage drop of the junction, but it won't amplify. B-E and B-C act like diodes.
      Some jfets will pass (not amplify) signal from source to drain and only need voltage to be turned off.
        Jfets typically are symmetrical, so drain and source can be reversed.
          Point contact transistors are also symmetrical, though you aren't likely to find one outside of a museum, unless you make your own.
            t
            It's not clear what you're asking.
            It is true that no transistor will amplify without a DC supply. As to passing signal, it depends on the type of transistor. For bipolar transistors, you can get only the kind of "passing signal" that a diode will do, as already noted. For specifically depletion mode JFETs and MOSFETs , they are normally on, so in the absence of DC and/or bias on the third leg, the drain and source will pass signal through. In the MOSFET, this is complicated by there being a built-in parasitic diode in one direction from drain to source. But JFETs, with nothing else attached, look like a resistor until biased off or until the signal gets big enough that the voltage drop along the drain-to-source resistance starts causing self-bias.
            But in general, no, you get no amplification or "passing signal" unless there is a DC supply. There are (always) asterisks and footnotes.
