Originally posted by The Dude
View Post
Assistance Using Scope to Troubleshoot
Originally posted by Perkinsman View PostTo be honest, I’m not sure what oscillation even looks like on a scope, I’ve only used it to see AC sine waves & that was awhile ago. Do I set the master & channel volumes at the point where the feedback occurs? Will that damage anything if I leave it feedbacking for awhile as I probe? Do I just start at the input & follow the signal path to the speaker out? Are there any places I shouldn’t touch with the probe?
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by The Dude View PostI'm starting to wonder if there is even a problem. Playing a guitar in close proximity to a cranked amp is often going to cause feedback. Is that what we have here? Is the feedback only when you stop playing the guitar, or is it constant once it starts? If you move further away from the amp, does the feedback stop?
The owner dropped by and brought an attenuator & hi wattage speaker so we were able to hear the feedback at low volume. We put the master at mid and the JCM started feeding back at 4 or 5. No feedback on the other channel at any volume. It would also feedback when we raised the tone controls at higher volumes. No feedback on the other channel at any level of the tone controls. None of the tubes emitted microphonic noises. Same Les Paul used on both channels. We're lucky enough to have a high profile guitarist's tech nearby so we decided it's best left to an expert. Thanks for the assistance and especially for the tip on Jack Darr's book.
Originally posted by Perkinsman View PostWe're lucky enough to have a high profile guitarist's tech nearby so we decided it's best left to an expert."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostJust to be clear, this guy knows about amplifier electronics? Not always the case. Confidence and vaguely related credentials aside,.. We are here if it comes up
That's like saying I'm a painter I can paint cabinets(and I do at work) but I ain't no Van Gogh....
Originally posted by nosaj View PostGuitar electronics half a volt of electricity Vs Amp Electronics hundreds of volts of Electricity.
nosaj
It's interesting to me that no one credited or acknowledged my recognition of no 0DC reference at the downstream end of the channel switch. That should be addressed and I'd only trust this 'known guitarists tech' if he/she recognizes it as well. If they don't mention it or correct it I think Perkinsman should return here or find an actual "electronics tech" for advice on matters of amplifier repair and modification.
JM2C"Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostIt's interesting to me that no one credited or acknowledged my recognition of no 0DC reference at the downstream end of the channel switch. That should be addressed and I'd only trust this 'known guitarists tech' if he/she recognizes it as well.
Seriously though, I did notice your valid statement with regard to the switch. Some of us may get a bit of 'tunnel vision' in terms of fault finding, which is why it's so good to have many eyes looking at problems as we do here.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI just assumed they were using a MBB type switch there."Take two placebos, works twice as well." Enzo
Originally posted by Perkinsman View PostThe owner dropped by and brought an attenuator & hi wattage speaker so we were able to hear the feedback at low volume. We put the master at mid and the JCM started feeding back at 4 or 5. No feedback on the other channel at any volume. It would also feedback when we raised the tone controls at higher volumes. No feedback on the other channel at any level of the tone controls. None of the tubes emitted microphonic noises. Same Les Paul used on both channels. We're lucky enough to have a high profile guitarist's tech nearby so we decided it's best left to an expert. Thanks for the assistance and especially for the tip on Jack Darr's book.Last edited by Helmholtz; 12-08-2019, 10:38 PM.- Own Opinions Only -
Originally posted by Helmholtz View PostIf it's not controllable but rather squeals it's likely due to microphonic PUs.
"mic drop""Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostYep. Like I suggested in post #9. Now we know an attenuator is being used as well so there's a possible reaction from that unit. Though the guitar was a Les Paul, which usually means humbuckers and they cancel external EMF's, but if it has p90's...??? Or it's instability. I think this is still a possibility because Perkinsman described being able to hear the feedback at low volume because the attenuator was being used. So all these possibilities should all be tested for if the described symptoms don't make it obvious to any local observer. In all immodesty I would know which of the three is causing the problem immediately had I been present for the test. I sincerely hope the guy taking charge now is qualified for the same confidence.
"mic drop"
