Post about differential probes...can't find it
    Originally posted by nickb View Post
    You can make your own probe for low cost: https://hackaday.io/project/169390-a...erential-probe
    Methinks this is a nice idea. One will be appearing on my bench soon
    That's a nice little project. I just ordered the PCB from OSH Park. 3 boards for $9.85USD, free shipping. I would power it with a battery instead of AC adaptor and no more lugging my isolation transformer onto the bench.
    btw: I have the rest of the schematics for the PF500 if they're needed. I got them at the Loudtech site before they disappeared. The last time I looked at a PF500 I gave up on it and it was trashed. I don't regret it!
      I am going to give this PF500 a shot....so far the only component I found gone was one of the output fets.....which are on order along with some of the support components should I need them....
      Cheers
        Generally speaking, if you find a blown output fet, replace the IR20957S driver ic also.
          I'm not getting what SG1 & 2 are ? I'm liking not needing a dual-trace though.
            Should be spark gaps realized by layout.
            https://hackaday.io/project/169390-a...-probe/details
              Hope it goes well! Please post the rest of the PF500 as I'd like to see it. Ta!
                I uploaded the PF500 schematics to https://music-electronics-forum.com/...9&d=1606088416
                  Thx dmeek.
                  Here is the power amp from that. If a FET is fried, replace both FETs the 4148 diode, 10 ohm resistor and driver chip. No probes required. A not unusual issue is a shorted output inductor which will blow the FETS due to excessive current. Often they are simple enough you can rewind by hand.
Name:	Class D Output.JPG
                    That's not the schematic for the board that I have....the board I have has 4 smt transistors between the gate drive IC and the main output fets......the correct schematic is back in post #12....
                      That's a nice little project. I just ordered the PCB from OSH Park. 3 boards for $9.85USD, free shipping. I would power it with a battery instead of AC adaptor and no more lugging my isolation transformer onto the bench.!
                      Populated??
                      wanna sell me one?
                        It's basically the same. In your case replace the driver transistors too. In many ways class D amps are easier to fix than AB.
                        • #27
                          I have all the parts ordered.....just waiting for them to arrive....
                          Cheers
                          • #28
                            Originally posted by SoulFetish View Post
                            Populated??
                            wanna sell me one?
                            Bare boards, All parts are smd. It is designed for 100MHz bandwidth. I might downgrade it to ~10 MHz The opamps I would use are less expensive and draw much less current.
                            • #29
                              That opamp driving the midpoint drives a heavy capacitive load. I see nothing in the datasheet that says it's not going to hoot like a banshee.
                              • #30
                                The board may have a bandwidth of 100MHz, but it would be difficult to compensate the whole array I would think. wouldn't changing the proximity of the 2 EZ mini-hook leads to one another alter the capacitance enough to cause HF errors?
                                I'm not set up to populate a smd board, you guys ever use a PCB manufacturer to fabricate and populate PCBs for you? what kind of minimum quantity and cost would that entail?
