Working on an oddball problem that appeared to be a simple bad connection somewhere. As luck would have it, the problem is aggravating since now I'm convinced it's a component breaking down.
This is from a post on another forum about the problem.
Hi
New here....
PEAVEY TRANSFORMER 112 Transtube amp
I've been trying to troubleshoot an odd problem on a friend's amp. The symptom is an intermittent crackling noise. After confirming the problem and removing chassis I did a lot of probing trying to locate cause of noise.
It has been very frustrating to locate the cause due to fact it doesn't appear to be a loose connection or bad solder joint. However since I can probe just about anywhere on the front panel PCB to make it come and go. The strange thing is it doesn't always respond to physical probing to create the problem. But once it starts, I can touch just about anywhere to make it happen... then other times I can hit with a hammer and nothing happens.
Just when you think the problem are is located, next time probing same area nothing happens.
Very odd problem.
Wondering if this might be a problem someone has heard of before. I've resoldered all the ribbon cables thinking that might be where problem is coming from but that didn't help at all. Certain stored programs seem to be very susceptible to noise while others are completely noise free.
Doesn't make a lot of sense.
There is understandably a LOT of components in this amp. I almost think it could be just a component breaking down and not a bad connection.
But I defer to any tech info related to this problem.
I have a short video with the amp doing the noise thing. You can see me probe different parts of the front panel PCB's to make noise come and go.
I'm a tube amp tech with little experience on Peavey transtube amps.
Any and all help appreciated!
If I can upload video I will.
********I WAS UNABLE TO UPLOAD VIDEO TO THIS MUSIC -ELECTRONICS FORUM WEBSITE. Apparently this website doesn't work the way some others do.
Too bad as it clearly gives you an idea what the problem is.
thanks one and all...
IT WOUKD BE GREAT TO FIND THE SCHEMATIC FOR THIS DEVIL.
GARY
Hi
New here....
Very odd problem.
GARY
