ooking for Yamaha CSP-150 Service Manual
  • ooking for Yamaha CSP-150 Service Manual
    For repairing purpose, please help
    https://mega.nz/folder/XNxjib4S#9AR-F6K5-ndfMYKWsU9cNA
      Thanks Sugeda for the help
        I am also repairing a CSP 150. It keeps turning off. Do you have the same problem? 非常感谢​
          Mine is not turn on, Dm Board problem, seems hard to repair
            Click image for larger version  Name:	led.jpg Views:	0 Size:	86.2 KB ID:	1005580
            Does the light turn on?​ If the light turns on there is probably a problem with the DM board.
            If the light doesn't turn on the problem is probably the power supply board. Or the small fuse board
            If I unplug my piano for 1 week, it will turn on and work for a few minutes. 麻烦死了​
              yes, the light is on, and I've check the Power Supply Board and it's fine, so the problem is the Dm Board
                My piano has the same problem. If I unplug my piano for a week it will work for a few minutes. If I unplug it for 2 weeks it will work for an hour.
                Next week I will use page 61 and page 85 in the Service Manual to test my piano
                Did you try unplugging for a long time? 看来无电有影响
                  It was the dm board
