Need Cerwin Vega SM-15B crossover schematic
  • Need Cerwin Vega SM-15B crossover schematic
    Hello Everyone, If any one could tell me the value of #3 capacitor on a Cerwin Vega SM-15B crossover that would be great. The cap totally burned up, and I can't find a schematic or wiring diagram ect.
    Many thanks in advance. Dehn
    https://www.ebay.com/itm/195718720344
    which one?
ID:	1006251 Click image for larger version
ID:	1006252 Click image for larger version
ID:	1006250 Thanks for replying x-pro, I see the sm-15 crossover and the sm-15b are different, the burned up cap is a small ceramic type. pics attached
        Maybe the "small ceramic cap" is actually
        a thermistor,
        a polyswitch
        or a varistor,
        all of which are protection devices and often die while doing their job in an extreme overload.
        Crossovers have few components (6-12 tops) and can be traced with a little patience.
        Position of "3" in the circuit will suggest function and value, for now draw it like a blank rectangle.
          Curious, what is a polyswitch & what does it do? Yes, I'm goofling it now.
          Edit: that wasn't nearly as exciting as the name "polyswitch" implied.
          Good to see you over here again.
          Jusrin
