Please, I need the schematics or service manual, is Simmons DA200S. Thanks.
Simmons DA200S
Here is what I have.
Rev F uses an STK module.
Rev G uses two TDA 729X amp chips in parallel.
I had a Rev G come through with a blown rail switching mosfet & a blown speaker.
It came back 2 weeks later in the same condition. (Grrr)
Turns out one of the TDA IC's was at fault.
Replaced both, replaced the rail switch mosfets & another speaker.Attached Files
- Likes 2
Thank you very much, Jazz P Bass. I found one speaker in bad condition, the bass doesn't work, I'm working on it.
I understand a quad rail 700W per channel rack amp but .... 50+50?????Juan Manuel Fahey
Originally posted by J M Fahey View Post
They certainly overcomplicated that power amp to get mere 50W per channel.
