New Month We are at $0 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
que lastima que los temas se terminan por que ya consiguen el diagrama me gustaria que cada tema siguiera no simplemente por lo que se necesita hay que estudiar y saber sobre los electrodomestico para asi poder sacarle una mayor ganancia
Bing translate:" that hurts that subjects end with that already get the diagram I would like each topic followed not just by what is needed there to study and know about the appliance in order to get a higher profit"
Hola alexisleidys, vas a tener que hacer un esfuerzo y manejar algo más de Inglés o al menos postear doble: en Español *y* la traducción en Inglés.
Y Google Translator es mejor que Bing.
Además escribe lo más posible en "Español de España" y con puntuación perfecta, los traductores son máquinas y para ellos "electrodomestico" no es lo mismo que "electrodoméstico", "que" no es lo mismo que "qué", "ideo" no es lo mismo que "idea" .... y si hablas de "comadre" nadie se va a dar por aludido.
Suerte.
^^^^^^^^^^^^^ just some tips to improve communication.
FWIW: Bing version:
Hello alexisleidys, you'll have to make an effort and handle something more English or at least post double: in Spanish * and * the English translation.
And Google Translator is better than Bing.
Also writes as much as possible in "Spanish in Spain" and with perfect score, translators are machines and for them "appliance" is not the same as "appliance", "that" is not the same as "what", "ideo" is not the same thing "idea"... and if you talk about "comadre," nobody is going to give hint.
Luck.
and Google version:
Hello alexisleidys, you have to make an effort to handle something more than English or at least post twice: in Spanish * and * the English translation.
Addition writes what more possible in "Spanish of Spain" and with perfect score, translators are machines and for them "appliance" is not the same as "appliance", "that" not what same as "what," "ideo" not the same as "idea" .... and if you say "godmother" no one is going to give the hint.
Luck.
Hey JP, Would you happen to have another version of this schematic with output amp board 4005197001C instead of the version here, which is 4005197001? The amp I have in my shop is actually a BJT HA-3500, but is different from the commonly available schematic... This one looks closer but is still a bit different, and component numbers vary -- different power transistors too. The "C" version board I have says "model 5000/3500B/7000B", so could be from any of these I guess, but so far no luck.
Cheers, Paul
Many thanks JP, the HA-3500_1_35 file is close enough for Rock 'n Roll! I got it passing audio, now just need to tweak the bias and offset today, and hopefully it will be good.
