Fender Rumble 100 Schematic req
  • Fender Rumble 100 Schematic req
    Cant find the Rumble 15,25,60,100 schematics anywhere (Not Rumble Bass) it's a different amp
    Anyone have one?
    Thanks
    I'm also searching for the schematics for the Fender Rumble 100/60 combos. Anyone?
      Fenders are like Mac or BK hamburgers, out of the same 5/6 components they make a zillion "different" products that are not so.
      I'm sure your amp's power amp is the same as what's used on *many* others and your preamp maybe only slightly different too.
      What's your specific problem?
      Describe your output transistors (Tip142/147 ?) and what drives them, it might be the ubiquitous (for Fender) MC1436 or a discrete design.
      Cosmetic changes on the front panel don't mean much "under the hood"
        Generally Fender will provide them if requested.
          Thank-you very much, Enzo.
            Here's a repost of the schematic if anyone wants it
            I have just put it here for anyone else that wants it.
            Laluna Technology - www.laluna.co.uk
              Here is a repost of the Rumble 60.
              Rumble 60.zip
                Does any one have Fender Rumble 100 schematics anywhere? Am using the model with 2x10s (https://manualzz.com/doc/en/51881037...owner-s-manual)
                Can help?
                  Hi, did you read through this thread? It is posted more than once. SCroll up and see.
                    https://music-electronics-forum.com/...etch?id=845213
                      I have copies of the Rumble 30, 75 and 100 if they are any use.
