PV Studio Chorus 210
  • PV Studio Chorus 210
    Peavey hasn't got back with me in a few days on this, so if anyone has a PDF print on this chassis that would help greatly. Also looking for one for an XR-500.....its been screwed with and I'm sure the output devices are not correct.
    My XR500 has a 260C power amp on the back, how about yours? And there are a couple versions of the 260C.
    Is your Studio CHorus 210 the 1988 or the 1990 version?
      The 210 amp is the later 90s teal/blk panel one. The XR500 is series 260c. I put it back together pending customer hem/haw so If/when I take it back apart I'll find a pcb revision. The main thing I was worried about on that is the outputs are not original and I wasnt to see what's s'posed to be there before I spec a replacement.
        Wanted that is....swimmin' pools....movie stars. Looks like they *were* original. I didn't think the were using RCA parts that late in the game. All the shitty resoldering on the pcb got me thinking someone had replaced the outputs with whatever *looked* like what came out. Its happened.....
          OK, then take THIS...
          And you probably already have it, but here is a file of PV's transistor cress ref.
            Groovy....that sets me up. Mad props brah
