Originally posted by g1
View Post
Crate GX-15R Schematic
Thanks g1. sure enough, I've got AC voltage across the two red wires. Sure glad I asked before I purchased anything. I'm no EE, and I don't know how much further I want to dig on this, there are just two diodes where it looks like they got hot on the ends, close to where the power comes in, but the rest of the board looks good, nothing looks burnt or bad at all. Any thoughts on what to measure or look at? I did measure across the IC chip mentioned above, and I have voltage across it as well.
Originally posted by chkline View PostThanks g1. sure enough, I've got AC voltage across the two red wires. Sure glad I asked before I purchased anything. I'm no EE, and I don't know how much further I want to dig on this, there are just two diodes where it looks like they got hot on the ends, close to where the power comes in, but the rest of the board looks good, nothing looks burnt or bad at all. Any thoughts on what to measure or look at? I did measure across the IC chip mentioned above, and I have voltage across it as well.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
I had this same issue except the power light (LED) illuminates and nothing else. I finally got all of the parts through "Mammoth Electronics" but have to be in the mood to do delicate work like removing the actual circuit board from the chassis in order to remove and replace I.C. circuits with soldering technique.
Joe
Here are some pics. I don't see any fuses, which amazes me for an electronic device. The first pic is a close up that shows just a little of the discoloration on the right ends of D18 and D11.
Imgur: The most awesome images on the Internet
Originally posted by chkline View PostHere are some pics. I don't see any fuses, which amazes me for an electronic device. The first pic is a close up that shows just a little of the discoloration on the right ends of D18 and D11.
Also before going too far take a battery and test the speaker You should get some noise when you touch the leads no sound bad speaker. If bad speaker leave it disconnected turn on the amp and measure for any DC at the speaker leads.
I also saw no fuse you may find it hidden in the power plug (IEC).
Those are some excellent photo's, I believe what you are looking at are resistors? There should be test points at certain resistors. The only fuse my crate had that was visible was an "In-Line" power fuse. The actual power supply has a stamp on it stating: "Thermal Protected" and after researching, I found out that it's pretty much a disposable power supply. I found my Crate Amp GX-15R at a thrift shop and only cost me $10.00 dollars. It worked great for awhile and then I started trying to connect it to another amp and that's when it broke. Now I am using it a as a learning tool.
Joe
Originally posted by nosaj View Postcan't really see the discoloration. Do you have a diode test on your multimeter? If so check those diodes that is your bridge rectifier converts AC to DC.
nosaj
Originally posted by chkline View PostI used the diode test on my fluke, and it looks like all. Three passed producing .53 V.
How to test diodes using a digital multimeter
Originally posted by nosaj View PostDid you reverse the leads to make sure it reads OL in the other direction?
nosaj
nosaj
Originally posted by chkline View PostI did, and it did not show OL, it had voltage and would just keep creeping up on all of them. Could these not be diodes? I don't see the normal diode symbol on them?
If your voltages at TP10 and TP11 are -+15v we can move on.
Originally posted by nosaj View PostYou should be testing with power disconnected. That silver band on one side usually indicates a diode plus the D11 stands for Diode 11.
nosaj
